when I try to send text messages I can only send them sometimes and more often then not I cant send any. it says try again but it keeps failing to send
What?! I updated and still receive the same problem, with sometimes an occasional text sending through. I am on WP 8.1 DP.
after black there is also a little firmware update, do that and your phone should work fine
