I am using lumia 830 past 1 year eveything was fine till update it to Windows 10. My battery started to drain out early and phone is getting heat. I am still using original Charger. When i use the mobile while it is charging the battery will drain out, if i need to charge the mobile the need to lock the mobile and should put idle.
