1. mayoo's Avatar
    I have Wall Charger and a car charger from blackberry. is it ok for using them on Lumia 900 ? Does anyone know what the Amp Specs Lumia needs ?
    04-11-2012 11:40 AM
  2. Mio_Ray's Avatar
    For the 800 they recommend 1000mA. I would put it like this. You can use them, but it is recommended to use the original charger as main charger. I think my BB chargers are only 750mA but I also still use them for the Lumia if they are closer... Bear in mind that a USB port in a PC only gives out around 300mA.
    It will take a little longer to charge and My experience is that the charged battery lasts longer when charged with a 1000mA (Or my 2000mA iPad charger)
    So, it can be used. But it is not the best option.
    Sent from my iPad using Tapatalk
    mayoo likes this.
    04-11-2012 01:23 PM
  3. Kon-Aitor's Avatar
    Do you know what the included charger does? What MHA does it charge at.
    04-11-2012 04:20 PM
  4. sting7k's Avatar
    5V @ 1A; same as Apple A/C adapters for iPods/iPhones. As long as you don't use a charger that is higher voltage it will be fine. Using an iPad charger that is 2A will charge it faster.
    04-11-2012 06:49 PM
