1. MEDaugherty's Avatar
    Is the battery replicable? Can the battery be upgraded? Can the battery be replaced by the end user? Will there be an extend life battery option? Will a cover with an integrated battery be made available and will it make use of the Qi charging method?
    Will the wireless charging stand provide enough support to secure the phone in normal vehicular use? Will a retention device be made available that will secure the phone to wireless charging stand? Does the wireless charging stand have a bottom suitable for a suction cup, double sided tape, or Velcro?
    How do you intend to energize your phone to the max?
    09-07-2012 11:58 AM
