I realize there are several threads about the battery life woes with the 920 but it seems to be a random occurrence. I normally get about 2 days out of my battery but occasionally the phone will heat up and will drain within 3-4 hours. I've tried to duplicate the problem at will and have ruled out any rouge app randomly draining the battery (background tasks disabled, no apps installed after reset).
For me it seems to be isolated to either wi-fi or bluetooth. The first indication of the run-a-way battery drain is the phone getting very warm, when this happens the battery shows from 18 hours battery remaining to 2-3. Interesting I disabled wifi and bluetooth and the phone cooled and battery remaining indicator went back to 9 hours after an hour or so. The next time the phone heats up with it's random battery drain, it would be interesting to disable ONLY the bluetooth as I believe it is the real problem.
Now for duplicating the problem, so far it seems to be occuring after using the camera for some reason, I have auto upload set to on (best quality, wifi only) and all wifi advanced setting are unchecked. There have been a few instances where I was taking photos well outside of any wifi signal when the problem occurred. I just can't seem to verify if it's wifi or bluetooth causing the problem, but with the various bluetooth bugs I've come across it wouldn't surprise me.
My experience is the battery life isn't just good for some, bad for others, but the seems random. Anyone else notice the random nature of this as well? If so, do you have wifi or BT enabled when it occurs? Love the phone, and it would be nice to provide some real info to help get a fix.
