1. darth_furious's Avatar
    When I first got my 920 I read about people who had phones that quickly discharged. Luckily mine worked fine. I'd have wifi, LTE, bluetooth all on and last through the day with 40% left. I noticed a small bump when I disabled NFC and changed the brightness setting. I was quite happy with the phone.
    I had many incidents where I didn't charge the phone the night before and the battery died on me. There were other times when I felt the phone run hot as I had GPS on while charging for hours. I think these 2 things damaged my battery. Lately it discharges about 20% every hour. I concluded that my battery lost the ability to hold the full charge (2000mah) and it was discharging at the normal rate, only now each mah was a greater %. [ie a good battery uses 100mah = 5% of 2000mah. Now 100mah = 10%...etc]. I ordered a new battery and switched it out and it runs great.
    For those with problems, maybe your battery is bad/worn? maybe you got unlucky and it was like that when you first opened the box. Maybe a new battery will fix your battery life like mine?
    07-23-2013 02:48 PM
  2. Muessig's Avatar
    I'm not 100% sure but I think manually replacing your own battery will void your warranty. Just thought I'd mention that. Really glad that you fixed your battery problems, though!
    07-23-2013 02:56 PM
  3. BIGPADDY's Avatar
    I would recommend sending it to Nokia Care if you still have warranty however it great that you fix and it all works.
    07-23-2013 03:04 PM
  1. Fix, replace or go for a 1020?
    By NutmegState in forum Nokia Lumia 920
    Last Post: 07-24-2013, 03:04 PM
  2. Why does the lumia 720 cost more than 820, 920?
    By tmpusr889 in forum Phone Wars
    Last Post: 07-23-2013, 07:25 PM
  3. Release date amber on unlocked 920's?
    By Fade_z in forum Nokia Lumia 920
    Last Post: 07-23-2013, 05:08 PM
  4. MY HTC 8XT review
    By johnbash612 in forum Microsoft News & Rumors
    Last Post: 07-23-2013, 12:39 PM
  5. E-mail problem
    By Ianpwalton in forum Nokia Lumia 520
    Last Post: 07-23-2013, 09:59 AM
