Fixed Front camera dust problem fixed with Nokia repair
loveleo
28
Got this ATT lumia 920 used and found a lot of dust near front camera and earpiece. Vacuum and dust it off blowers took away the dust in the earpiece but not in front camera lens. Luckily it is still in Warranty so sent it to repair. Took two weeks including shipping time. All free of charge, not bad.
The lens does look clean now with no dust and picture quality much better although still the vga quality.Does have a relief now that it won't have the proximity issue any more.
Got a case and using it last night with tuen in fm, cannot connect to some stations and eventually got frozen maybe due to overheat. Soft restarted and took it off from the case and went back normal. Maybe the fix does affect the heat dissipation a little.
velocityxs
