1. loveleo's Avatar
    Got this ATT lumia 920 used and found a lot of dust near front camera and earpiece. Vacuum and dust it off blowers took away the dust in the earpiece but not in front camera lens. Luckily it is still in Warranty so sent it to repair. Took two weeks including shipping time. All free of charge, not bad.
    The lens does look clean now with no dust and picture quality much better although still the vga quality.Does have a relief now that it won't have the proximity issue any more.
    Got a case and using it last night with tuen in fm, cannot connect to some stations and eventually got frozen maybe due to overheat. Soft restarted and took it off from the case and went back normal. Maybe the fix does affect the heat dissipation a little.
    09-25-2013 01:25 PM
  2. Laura Knotek's Avatar
    I'm glad to hear that the repair fixed the dust problem.
    09-25-2013 01:28 PM
  1. Nokia Lumia 920 ATT
    By john_v in forum Marketplace Archive
    Last Post: 10-30-2013, 11:36 AM
  2. Replies: 6
    Last Post: 09-28-2013, 11:15 AM
  3. Nokia Panorama app - fixing via buil-in mechanism
    By josipogo in forum Applications
    Last Post: 09-26-2013, 12:46 AM
  4. Glance screen problem
    By Pritesh Bishi in forum Nokia Lumia 720
    Last Post: 09-25-2013, 03:39 PM
  5. Nokia Lumia 920 EU Belgium Rom GDR2
    By BertJan De Spiegeleer in forum Nokia Lumia 920
    Last Post: 09-25-2013, 02:38 PM
