My lumia 920 screen inside have water vapour!!!!!! how to solve ??? HELP!!!!!!!!!
Paul May
Lumia 950 & Surface Pro Champion
Nov 8, 2012
347
My advice would be to put some uncooked rice into a tub and place the phone in the tub (obviously turned off) for a few days.
Paul May
Nov 8, 2012
347
how many days ? its works?
Look it up online, im sure it varies depending on how much moisture is trapped but uncooked rice is supposed to draw out moisture from electronic devices. The only other issue is depending on how long the moisture has been inside the device it can cause corrosion to the device so you need to try this asap.
theppy
19
sun is the worst answer, i did that and now my phone is dead. waiting for the people to call me back and tell me how much will cost to fix it.
VisualD
45
Dry rice in an enclosure or better yet silica bags as quick as possible as oxidation is brutal for any electronics and gets worse by the hour.
ailanamargarett
