I Illusive Recluse New member Dec 10, 2013 5 0 0 Visit site Aug 21, 2014 #1 Deleted Last edited: Sep 2, 2014
Rafael Yousuf New member Oct 19, 2013 358 0 0 Visit site Aug 21, 2014 #2 Use the Nokia software recovery tool, you can use it to download the firmware and flash it
V VineRider New member Apr 24, 2012 213 0 0 Visit site Aug 21, 2014 #3 Are you in the US on AT&T? If so, wonder if they are in the process of updating the download to Cyan?
Teeeerex New member Jul 18, 2014 70 0 0 Visit site Aug 21, 2014 #4 You can use any product code as long as it is for the same RM-XXX. To be safe, make sure it is meant for the country you are using the phone in.
Teeeerex New member Jul 18, 2014 70 0 0 Visit site Aug 21, 2014 #5 Nokia Care Suite is the only one that will work.
