1. mojacho's Avatar
    Dear All,
    i would like to seek your kind assistant & help. My nokia Lumia just fall off & No Crack on the screen. only dead pixels on the screen.
    question : what parts should i purchase to replace this screen?
    your kind help & suggestion is much appreciated.
    Regards,
    11-01-2015 11:49 PM
  2. Jazmac's Avatar
    Buy a new phone. These things are not worth the repair costs
    11-02-2015 12:07 AM
  3. mojacho's Avatar
    can someone let me know the part name for this? i am thinking to buy this parts. thank in advanced.
    11-05-2015 03:35 AM
  4. PepperdotNet's Avatar
    Take it apart, check the connections. It's possible something is still partly connected but loose. If that doesn't fix it, you likely need a new screen. Because you don't repair phones for a living and don't have all the expensive equipment for separating and joining these parts, you need the entire glass/screen/lcd/frame assembly. For the 920, I've seen those at around $30 on ebay. Example: Front Full LCD Display Touch Screen Glass Digitizer Frame for Nokia Lumia 920 | eBay (just an example not an endorsement or recommendation of the seller)
    mojacho likes this.
    11-05-2015 08:32 AM
  1. Screen wobbling is a REAL issue!
    By john_ferrier in forum Microsoft Surface Book
    Last Post: 01-12-2016, 03:57 PM
  2. is nokia lumia 930 is compatible
    By umi_ali in forum Nokia Lumia 930
    Last Post: 11-03-2015, 10:26 PM
  3. Flashing blue screen?
    By ncxcstud in forum Microsoft Surface Pro 4
    Last Post: 11-02-2015, 08:51 AM
  4. This Week in Xbox One News - Aaron Greenberg speaks, Witcher 3 awards, Fallout 4 screens & more!
    Last Post: 11-01-2015, 07:30 PM
  5. Replies: 0
    Last Post: 11-01-2015, 01:57 PM
