    I've had my L920 for two years now. I still don't understand why using GPS in the car drains the battery faster than the charger can charge it.
    I had been charging the phone using an AC inverter which allowed me to convert the 12v DC power to 230v AC. With that I connected my standard home charger to the inverter. This worked perfectly, it charged the phone quickly and I was able to use GPS on long journey without worrying about getting stranded with a flat battery and no GPS.
    Recently the alternator in my car went bad and I replaced it. I decided it was time to stop using the AC inverter because going from DC to AC is very inefficient and I didn't want to put an excessive load on my new alternator.
    I researched this heavily because I knew that all the chargers I'd tried in the past didn't cut it.
    I bought an Aukey charger which has two 2.4a 5v USB outlets. (far greater than the AC charger). I also bought a PortaPow charging cable.
    After using it for a few months, I've reached this conclusion:
    The new set up works if brightness is set to low and 4G is disabled. If I start my journey with 100% battery, I will arrive at my destination with 100%; however, if I start a 2 hour journey with 50% battery, I won't have 100% when I arrive.
    It charges faster with an AC charger which has a lower current output. Why?
    I'm still having to carry the AC charger everywhere I go because charging in the car during my commute is still not viable unless I use the dirty inverter.
    11-27-2015 10:49 AM
  2. eusty's Avatar
    I found this on my 930 until I changed the car charger to a 2A version.
    11-27-2015 11:35 AM
  3. HerronScott's Avatar
    Most of the car USB chargers with 2+ amp outputs are designed for iPhones and will only end up charging Windows Phones (and Androids) at .5A which is not sufficient to keep up with GPS usage and charging.
    I just replaced our car chargers with these when they were on sale for $8.99 and they work great with our Nokia 920's. They charge at about 1.3A according to my USB meter.
    Amazon.com: USB Car Charger,Tronsmart Quick Charge 2.0 42W 3 Ports USB Rapid Car Charger for Galaxy S6 Edge Plus, Note 5, Xperia Z5, Zenfone 2 and more (Includes a 20AWG 3.3ft USB Cable): Cell Phones & Accessories
    I would think that any that advertise Qualcomm Quick Charge should work well though.
    Scott
    11-29-2015 09:51 PM
  4. Erick Rmz's Avatar
    I had same problem with my 920 mainly using GPS, solved it using an USB adapter 12 V-5 V, 3.2 A, and works perfect. Even using a 2 A charger didn't worked.
    Cheers,
    12-02-2015 04:40 PM
  5. HerronScott's Avatar
    Cheers,
    Can you let us know the details on the one you bought (manufacturer, model number etc)?
    Scott
    12-07-2015 07:48 PM
  6. Erick Rmz's Avatar
    Scott
    Sorry I saw this until now. Don't remember manufacturer but bought it in Bestbuy a year ago, I think. I'll try to remember tonight to check out manufacturer and model.
    Tried at Bestbuy web and found this:
    Belkin Belkin Dual Car Charger with F8J071bt04-BLK - Best Buy
    or this:
    Image Auto Adapter Multi IMG-CE0136-NB - Best Buy
    Both should fits well.
    Hope it helps,
    cheers,
    12-15-2015 06:02 PM
  7. HerronScott's Avatar
    or this:
    Hope it helps,
    cheers,
    The first one comes with an Apple Lightning cable and indicates that it's designed for Apple devices so probably will have the same limitations as most USB chargers with Windows Phones and limit charging to 500ma.
    Scott
    12-21-2015 07:01 AM
  1. 950XL vs Nexus 6P - anyone interested in comparison?
    By coolbreeze78 in forum Phone Wars
    Last Post: 02-06-2016, 07:01 PM
  2. WTS: Unlocked <redacted>
    By drtek in forum Marketplace Archive
    Last Post: 11-27-2015, 06:07 PM
  3. How to enable Battery Saver automatically on the Lumia 950 and 950 XL
    Last Post: 11-27-2015, 10:42 AM
  4. How to fix Hey Cortana on the Lumia 1520 and Lumia 930 with Windows 10 Mobile
    Last Post: 11-27-2015, 10:20 AM
  5. Confused about region sales in windows store
    By Krystianpants in forum Microsoft News & Rumors
    Last Post: 11-27-2015, 10:10 AM
