1. Skaterbuoy's Avatar
    Hi, Some advice from other road users please?
    I have Lumia 925 and use the Nokia Here Drive app. Whilst out yesterday I noticed that the phone is not able to run the Dive app and charge the phone sufficiently at the same time.
    Although the phone said it was charging via a 2.1amp adapter and cable, it just ran out of change and powered off.
    After the phone re-set and as it was still connected to the power source, did after few minutes powered back on and seemingly continued to charge.
    I have had problems charging previously, but I thought getting a 2.1 amp adapter would have solved my problem
    My question, is there an issue with my phone or adapter, as to why it can't run the app and charge sufficiently at the same time?
    I have the latest Black update and associated firmware o/s updates. Any comments would be appreciated
    Cheers
    Paul
    01-26-2014 05:27 AM
  2. DBDev's Avatar
    Welcome to WPCentral!
    It should charge, however I have seen other people with the same problem, so it might be that Here Drive is taking that much power...
    01-26-2014 05:43 AM
  3. ratsttam's Avatar
    Are you running with the your local map donwloaded, or are you pulling the map as you go? Running GPS and a stream of Data can be pretty rough on any device.
    Where are you seeing that it's getting the full 2.1a charg, instead of the .5-1a normal charge?
    01-27-2014 01:55 PM
  4. KarateDad's Avatar
    It seems that running the GPS, the screen and data takes most of the power from an adapter. When I run Waze, my battery actually drops while plugged in!! I do get a slow charge on Here Drive, but I also went to a 2Amp car charger.
    01-30-2014 12:32 PM
  5. mcheiron's Avatar
    I have the same issue with my 920 and Here Drive. Even plugged in, standard charger, the charge is dripping and after 3-4 hours the phone is dead. Unplugged it takes 1 hour. The map is local.
    03-01-2014 03:29 PM
  1. Replies: 9
    Last Post: 03-24-2014, 05:59 PM
  2. BBM for windows phone leaked with pictures here
    By azarighty in forum Windows Phone 8
    Last Post: 02-04-2014, 10:29 AM
  3. Replies: 11
    Last Post: 02-04-2014, 08:59 AM
