Hi all, I saw this shell on the UK website and it said that it was "Coming Soon". I went and checked Amazon, and low and behold, Nokia themselves were selling this very shell. I then went onto eBay to try and find the cheapest price, which I did at around ?17. When I received the shell, I was really overjoyed with it, I tested it out and it worked. After a few days of playing around with it and showing it off to my colleagues and taking the case on and off multiple times, I began to notice small cracks on each of the corners.
I just contact the seller on eBay and he told me I had to contact Nokia about it and hand it to them. I went on the site and can no longer find this shell on there (something is fishy here). Just contacted Nokia themselves through Twitter, but have had nothing back. What I want to know is how many people have bought this shell and had the same or similar problems? Also, if you have had problems, how did you go about getting it replaced?
If you were considering getting this shell at some point, I wouldn't recommend it until the brought out something a bit more sturdy and won't crack just from removing it and placing it back on.
