What battery saver app do u use?
Sent from Seattle using Tapatalk
This is bizarre! It seems like your Microsoft ID was stuck in sync. Can you check under email+accounts if your Microsoft account keeps greying out again and again?
Try soft reset.....:wink:
The same thing happened to me.I tried everything..and after 2 days i did a hard reset like you..and that solved a problem. It happened 10days ago...Tried that a few times. Didn't work. Ended up doing hard reset (which I absolutely HATE) and it seems fine now. I wish MS would iron out these battery drain loop bugs.
