I recently bought a Lumia 925 i will be using in future (maybe... if i'm unable to repair my Lumia 820).
But this phone hase some major problems. I can't really use it as a phone right now. It's just for mobile Internet/WhatsApp right now. That's because the primary microphone doesn't work and the earpiece acts weird.
Symptoms are:
- Primary microphone does not transmits any voice during regular phone call. Only weird static noise
- Earpiece transmits a very distorted/buzzing voice of the caller. So it works somehow... but not usable
- If you switch to "handsfree mode" that it uses the speaker on the back and the secondary microphone on the top... everything works perfectly fine (but i won't use that option in public)
- WhatsApp calls work perfectly fine on all mics/speakers/earpieces
Are there any known solutions to that kind of issue?
Kind regards,
eviltrash
Symptoms are:
Kind regards,
eviltrash
