1. eviltrash's Avatar
    I recently bought a Lumia 925 i will be using in future (maybe... if i'm unable to repair my Lumia 820).
    But this phone hase some major problems. I can't really use it as a phone right now. It's just for mobile Internet/WhatsApp right now. That's because the primary microphone doesn't work and the earpiece acts weird.
    Symptoms are:
    - Primary microphone does not transmits any voice during regular phone call. Only weird static noise
    - Earpiece transmits a very distorted/buzzing voice of the caller. So it works somehow... but not usable
    - If you switch to "handsfree mode" that it uses the speaker on the back and the secondary microphone on the top... everything works perfectly fine (but i won't use that option in public)
    - WhatsApp calls work perfectly fine on all mics/speakers/earpieces
    Are there any known solutions to that kind of issue?
    Kind regards,
    eviltrash
    03-20-2016 04:01 AM
  2. Karthik thm's Avatar
    you can try reinstalling the OS from Windows Device Recovery Tool. Below is the download link. http://download-fds.webapps.microsof...lInstaller.exe
    04-06-2016 02:09 PM
  1. Luma 535 WM10/ Games issue
    By Traian Gaming in forum Microsoft Lumia 535
    Last Post: 03-23-2016, 04:10 PM
  2. Replies: 19
    Last Post: 03-23-2016, 01:14 AM
  3. Problems with Windows store launch?
    By darshakdhebar in forum Microsoft Lumia 540
    Last Post: 03-20-2016, 02:48 AM
  4. Replies: 1
    Last Post: 03-20-2016, 01:53 AM
  5. BLU WIN HD LTE X1500Q not updating with Windows Insider, what am I doing wrong?
    By Windows Central Question in forum BLU Win HD LTE
    Last Post: 03-20-2016, 12:25 AM
