1. phone_newbie's Avatar
    I have many problem in Lumia 925 :
    Wifi - when I try to switch on, it says "Can't do this right now". Because of this,
    I can't update to Lumia Denim (still Lumia Cyan), change phone language, download offline maps, download large files
    Bluetooth - can't switch on (stuck to off)
    Internet sharing - it says don't have internet connection
    FM radio - "loading..." appear and stuck like that for long time
    I tried "reset your phone" from setting, hard reset, Windows Device Recovery Tool (firmware 3051.50009.1424.0001 and it says the latest update). Result : No change at all, still have the problem.
    Anyone know how to fix that?
    03-30-2016 05:46 AM
  2. charlatan1978's Avatar
    Even though it said latest update, did you chose to reinstall?
    You will need to sign up to the Windows Central forums, so that you can reply to this thread to get more help.
    03-30-2016 05:55 AM
  3. phone_newbie's Avatar
    yes I reinstall using Windows Device Recovery Tool, but still have problem, no fix at all
    03-30-2016 06:47 PM
  4. charlatan1978's Avatar
    The only other thing I can think of is for you to install the Insider app and chose the 'Production' ring.
    Then check for updates.
    03-31-2016 04:32 AM
  1. Lumia 640 xl or Lumia 830
    By thisara98 in forum Microsoft Lumia 640 XL
    Last Post: 05-03-2016, 08:55 PM
  2. Is Windows Hello available on the Lumia 930?
    By Windows Central Question in forum Nokia Lumia 930
    Last Post: 03-30-2016, 10:45 AM
  3. Replies: 0
    Last Post: 03-30-2016, 05:10 AM
  4. Windows 10 version 1607 referenced in new documentation for UWP apps on Xbox One
    Last Post: 03-30-2016, 03:50 AM
  5. My Nokia Lumia 630 phone has a virus, how can I remove it?
    By Windows Central Question in forum Nokia Lumia 630
    Last Post: 03-30-2016, 03:15 AM
