1. tallarob's Avatar
    For the past several months, I thought my phone might be possessed. Every night, usually several times, I would hear what sounded like a text notification and the screen would come on for a few seconds. When I checked, there was never a text. I then started thinking it was some notification from either a sports or news application. I went through all of my apps and turned of notifications. Still, the problem persisted. I then thought it might be related to Glance, and turned that off. No luck.
    Last night, as I set the phone on my wireless charging dock, it dawned on me what I was hearing and seeing was exactly what happens when you first place your phone on the wireless charging station. I then decided to charge my phone with the wired charger and, lo and behold, no waking up of my phone!
    Granted, this is just one night, but I think I have solved the problem. Now my question is why is this happening? Is it a problem with the charger or with the phone? Has anyone else had this same problem?
    09-26-2013 09:58 AM
  2. digend's Avatar
    Yeah this has happened to me a few times.
    Are you using a Lumia 1020 with the wireless cover? In my case, I think the cover just doesn't do a great job of making contact with the phone. Re seating the case usually fixes the problem, though it kind of defeats the purpose of the convenience of wireless charging.
    09-26-2013 10:21 AM
  3. tallarob's Avatar
    I have the Nokia 928.
    09-26-2013 10:25 AM
  4. hopmedic's Avatar
    Imagine that, in the Lumia 928 forum! No way!
    09-26-2013 11:14 AM
  5. berty6294's Avatar
    Happens to me every now and then. One time it just stopped charging altogether in the middle of the night. I blame GDR2, its only happened since then. Still not a huge deal to me.
    09-26-2013 11:30 AM
  6. mjperry51's Avatar
    I'm shocked --- shocked I tell you. . .
    09-26-2013 07:21 PM
  7. StevePT's Avatar
    I've heard it as well... I just figured it was notifying me that it was done charging because the phone is completely charged and the light on the charging plate is off when I go check on it.
    09-27-2013 02:03 PM
  8. jasqid's Avatar
    For what its worth... my 8x stops charging wireless on the JBL or Charge Stand. And it seems to be more after the GDR2. Yeah I know this is the 928 forum... but I just won one on ebay and Im reading up on it.
    09-27-2013 11:32 PM
  9. icstars989's Avatar
    Mine has always done that. I assume its because after you're 100% charged, it stops charging. After so long your battery will drain and it just starts charging again.
    09-30-2013 08:58 AM
  10. tallarob's Avatar
    Makes sense. Drives me nuts though.
    09-30-2013 08:44 PM
  11. metesh1028's Avatar
    I purchased my 928 this summer, and just recently bought 2 wireless chargers, one for home and one for work. On both chargers my phone will charge for awhile and then the white light shuts off like its at 100%...only it's not! usually less than 50%. Any ideas to troubleshoot? Haven't dropped or damaged my new phone to damage the wireless charging hardware.
    Thanks for the help.
    09-30-2013 10:13 PM
  1. Wireless Charging Mod, Nokia Lumia 520 /521
    By WeAreNotAlone in forum Nokia Lumia 521
    Last Post: 10-08-2013, 12:58 PM
  2. Charging dock using Palm Touchstone...
    By duncanjameshill in forum Cases & Accessories
    Last Post: 09-27-2013, 08:41 PM
  3. using excel from skydrive on windows phone
    By pdoan_98 in forum Nokia Lumia 925
    Last Post: 09-27-2013, 08:37 PM
  4. Screen not working, Need to Sync Phone
    By electricbopeep in forum Nokia Lumia 900
    Last Post: 09-26-2013, 07:12 AM
