What can I do on my 928 that wont drain the battery like crazy? Games kill it. Streaming music kills it. Surfing web kills it. Setting screen on low doesn't help at all. Is this a 928 issue or windows issue?
I'm getting really frustrated but I dont want to go back to android.
I am not sure what you mean? The battery is draining like crazy when you play games and/or stream music? Those are two very intensive task on a phone, so hence you will see battery drain in those cases. As for surfing the web, are you surfing via Wifi or mobile connection?
I know it is standard answer, but have you tried going to settings--> applications and turned off any background task not necessary? And as a last resort, you can do a factory reset and see if if "cleans out" something that is the problem.
I have been using the 928, with GDR3 preview and have not really ever had any major battery issues, other than when playing games, which is to be expected.
