1. loukkis's Avatar
    When I charge my phone overnight and take it out of the charger in the Morning and when I look battery meter, it is fully charged. After 15 minutes and no use at all, when I check battery meter, it is somewhere in 93-94% readings. After that "rapid discharge" everything seems normal, battery level drops 1.5%-3% per hour. Does your phone do that or is my phone or battery broken?
    08-02-2014 03:36 AM
  2. Racing Snake's Avatar
    Mine does exactly the same, no idea why... psychologically I want it to stay at 100% for longer than 10-15mins, even if it does seem to perform well after that!
    loukkis likes this.
    08-02-2014 04:13 AM
  3. Headfx's Avatar
    I'll charge the phone till it says 100%, but if I then restart the phone the meter will sometimes read around 93/94%. One time this week I restarted the phone while the meter was at 83% and when it came back it read 100%! Then it dropped back to about 83% a few minutes later. Something definitely screwy going on I think.
    08-02-2014 06:23 AM
  4. iwang's Avatar
    I remember days of android batter meters...reset..hard reset..clear dalvik..etc..now my 930 is not yet consistent..still learning on where is the,0 and where is 100%
    08-02-2014 06:35 PM
  1. Nokia Lumia 900 unlocking?
    By chandad4 in forum Ask a Question
    Last Post: 08-06-2014, 03:22 PM
  2. Problems with onenote
    By devlam in forum Applications
    Last Post: 08-05-2014, 02:38 PM
  3. Lumia 1520 vs. Lumia 920
    By msalmank in forum Nokia Lumia 1520
    Last Post: 08-03-2014, 11:16 AM
  4. lumia 720 screen freeze
    By hari pavan in forum Ask a Question
    Last Post: 08-02-2014, 02:42 AM
  5. Lumia 1020 + Preview for Windows Phone + Cyan + whatever else is out
    By tbonecopper in forum Windows Phone 8.1 Preview for Developers
    Last Post: 08-02-2014, 02:03 AM
