Why isn't my Lumia 930 opening after a battery drain?
  • Start date
Lumia 930 Not opening after battery drain.
hi, my lumia 930 is not opening after my battery got drained. I have installed Technical preview 10. 10149. I have tried pressing all buttons combined as well as single button. nothing is working.
windows recovery tool is not detecting my phone as phone is in switched off condition.
uniquesma
13
Re: Lumia 930 Not opening after battery drain.
In between when my battery ws about 2% I used a Samsung charger as I got nly dat charger, as I ws on way. after that the phone got switched in 10mins.
Yugiro
19
That's weird, because for Lumia devices, you don't need to turn it ON to power up when you are charging it. The phone will automatically turned ON when plugged. How did you know that the phone is charged max? Did it show any icons or anything on the screen?
xandros9
Nov 12, 2012
16,107
try multiple cables and wall outlets?
I'd try looking at MS Mobile's support pages. It might run you through some of the same stuff.
taylormcintire
