What's the product code for Lumia 930 (Black) for Sri Lanka
ar21
4
True, but firmware files (from NAVIFIRM) have number 1083 in their names for above code. Sorry that I cannot post links, but if you search microsoft site for lumia denim updates by country, you will come up with SRI-LANKA latest update firmware. Crossing that info with NAVIFIRM brings up above code.
ar21
4
You launch NAVIFIRM.
You enter product code 059W227.
It will look the database and display on the right window the list of firmware files that can be downloaded.
You will see, for example, among them a file like :"RetailModeNvi_02540.00019.15236.45004_1083_87802a046b90805a6c93e77a5b212595".
You will notice that file name contains _1083_. It means that this is the right firmware for you.
Of course you must download all the file under 059W227, not just this one. Most updated firmware is 02540.00019.15236.45004.
Hope it helps.
DrPendragon
