    Hello,
    I own a Lumia 930 and this morning I woke up with my phone turning on and off by itself. It turns on, the 'Nokia' screen shows up, 3~5secs after that it turns off, vibrates and turns on again, and the loop goes on.
    Sometimes the 'turn off' takes a little longer to come, and the phone keeps booting until the 'Windows Phone' screen, and then turns off and reboot; Sometimes it even starts, but the lock/unlock screen doesn't work and it keeps going to the 'slide to turn off' screen, and even if I keep canceling the 'turn off' action, sudently it turns off and then turns on again and restarts the looping.
    Any chance of getting it working again without have to send it to the repair central?
    Thank you guys a lot!
    02-04-2016 03:07 PM
  2. gpobernardo's Avatar
    Yup, it looks like that something is stuck in the physical power button. You can either use a small strip of paper to try to clean in between and underneath the button GENTLY, or use a can of compressed air to blow* into the space in the between the button. If you have a hand-pump for those inflatable toys or life-savers, that should also work.
    *- Do not use your mouth. Moisture in one's breath (even without the splattering of saliva) could condense inside the phone and may cause additional damage than repair.
    You may create a Windows Central account to Reply in this thread.
    02-04-2016 03:12 PM
  1. Windows 10 Mobile not restoring SMS from the cloud ?
    By Pouknouki in forum Windows 10 Mobile
    Last Post: 02-04-2016, 02:34 PM
  2. Glue mark on Lumia 950xl
    By Mike Santagata in forum Windows 10 Mobile
    Last Post: 02-04-2016, 02:17 PM
  3. VAIO Phone Biz gets shown off for the cameras
    Last Post: 02-04-2016, 01:42 PM
  4. The best Acer laptops you can buy
  5. Get 30% off the Surface 3 Education Bundle until June 30
    Last Post: 02-04-2016, 01:11 PM
