Finally got bluetooth to work between my Galaxy S and the Surface Pro 3:
One time set-up:
1. Press the "settings" Charm - Change PC settings - PC and devices - bluetooth. From there you pair the phone and the computer.
2. Tap the back arrow and tap Control Panel - Device Manager - Bluetooth - double click Marvel AVASTAR - power management - uncheck the box, "Allow the computer to turn off this device to save power".
3. The bluetooth icon should now be in the task bar of the desktop view and active. You might have to tap the little white arrow to see it. Use the "customize" button to place the icon permanently on the taskbar.
That's it. To get a photo off your phone, click the bluetooth icon on the task bar and tap "receive a file". Then view the picture on the phone and send via bluetooth to the computer. The Surface screen will change to "receiving".
Now the reason behind doing this is because the camera in the Surface Pro 3 will not take close-up photos, like a check or a letter. (Total MS brain fart.) But my Galaxy S takes great closeup photos. With bluetooth, I can quickly get a photo into the Surface Pro 3's pictures folder.
I transferred about 40 pics in the matter of seconds
The process that Michael described transfers the 5MP jpg versions which are about 1.5MB each. The DNG RAW hires versions are 20MB each and take a lot longer to transfer.
In the time it took to transfer 10 5MP (1.5MB) jpg images, I only managed to transfer about 2 of the 16MP (20MB) DNG RAW versions.
You are correct though. It is rather easy to do.
