gjrincon
I've found that the biggest battery drainer in my Icon is having the Wi-Fi on. I had been getting decent battery life (0.3-0.5%/hr) until I changed the Wi-Fi settings to "Keep Wi-Fi on when screen times out", which can be set in the advance Wi-Fi options. This brought battery consumption up to 3-5%/hr. So, I now keep Wi-Fi off all the time or disable the "Keep Wi-I on when the screen times out" option, and battery life is back to normal. By the way, I'm running WP 8, and have almost all my apps running is background. I should also mention that LTE signal in my area seems to be fairly strong and stable.
