1. hokie_sec94's Avatar
    I recently started using a wireless car charger with my Icon running DP 8.1.1. While the charging works great, I am having UI stability problems. I can best describe the problem as phantom touches as it acts as if I am interacting with the UI, opening up the app screen, selecting apps, switching between apps, etc. Has anyone else experienced this issue? The wireless charger I am using is the PowerBot PB1040.
    11-01-2014 10:13 AM
  2. gernerttl's Avatar
    Maybe the arm is pressing a button. The charger doesn't haven't built in NFC does it?
    11-01-2014 01:47 PM
  3. hokie_sec94's Avatar
    No NFC and it happens whether held tightly by the sides or is just laying on the charger
    11-01-2014 08:51 PM
  4. gernerttl's Avatar
    I'm stumped. The only thing I can think of is somehow the screen is getting pressed...maybe on the edges. The only way to isolate would be to try it with an Icon running WP8.0 and see what happens.
    11-02-2014 01:50 AM
  5. surfacedude's Avatar
    you've answered your own question. i blame the phantom.
    gernerttl likes this.
    11-02-2014 09:11 AM
  6. PhalanxPunx's Avatar
    Have you tried the old reboot/reset method?
    11-04-2014 06:58 PM
  1. Lumia 730 low brightness problem
    By amit kaushik22 in forum Nokia Lumia 730 & 735
    Last Post: 11-08-2014, 08:22 PM
  2. windows store problem
    By nokianewbie in forum Nokia Lumia 920
    Last Post: 11-01-2014, 10:41 AM
  3. Where are my contacts on my Lumia 625 after I copied them?
    Last Post: 11-01-2014, 10:16 AM
  4. How to use LAN with out internet in windows phone?
    By Muralidhar Parimi in forum Ask a Question
    Last Post: 11-01-2014, 05:57 AM
  5. Bluetooth Connectivity Problems? Check this MS page for fixes
    By MadSci2 in forum Microsoft Band & Band 2
    Last Post: 11-01-2014, 03:43 AM
