Charging rate reports 16.05% per hour...but battery is not actually charging
I'm getting a false report on the charging status. While the screen in the battery app says "Charging Rate 16.05%", the graph continues to show decline, and the present battery percentage is dropping 71...70...69. Obviously the phone isn't charging, but is there something I can do (besides change the cable)? Reboot did nothing. Charging rate is always 16.05%...never more or less. When I reposition the cable, the discharging rate does vary from 3-12%.
My charging cable at work might be failing on me after 6 months of constant use. (It was a 3-pack and the others work fine.)
Data connection still works fine...able to browse files on the phone.
