    Lumia Icon With latest version on Denim Software
    Trying to make the Jump to Windows 10
    Installed Windows insider and started install.
    All seemed ok phone was about 50% charge then went to spinning gear screen left phone on charger and let it do its magic over night.
    Woke up this morning now phone is constantly showing spinning Gears then restarting and going back to spinning gears over and over.
    Tried Lumia Recovery tool and no luck Also tried cooling phone while on charger . No luck...... Any help would be appreciated!!!
    10-20-2015 09:08 AM
  2. uness's Avatar
    11-05-2015 03:42 AM
  3. uness's Avatar
    I'm in the same case, keep trying to hard reset but doesn't work. Would be grateful if any help. I think that we have to flash new stock rom of Windows 10 but it's not available yet u guess.
    11-05-2015 03:46 AM
  4. Alanatron5's Avatar
    I had the same thing happen to my Icon. This is what worked for me. Download the Nokia recovery tool for retail. Disable all your computer firewalls, very important! I had to to do a hard reset for the program to find my phone. It took about 10-15 and it will wipe out everything on your phone, but the good news is that all your contacts are backed up in outlook. The tool reset my phone back to windows 8. I downloaded windows preview again and got windows 10 latest build installed. It's ok...... I'm not able to use Cortana and can't download any other email accounts besides outlook. Hope this helps 😊
    11-15-2015 01:29 PM
  5. dunker2390's Avatar
    I also had this problem and I believe it has something to do with the Icon specifically(hardware/firmware). Posted the same issue on here and XDA but no one ever came up with a solution.
    I reset the phone back to 8.1 more than 3 times and each time I would install Windows Insider and proceed with the same steps to install windows 10. It failed every time and I ended up just letting the phone think it ran out of battery and shut off for a week(it's a spare Icon I have).
    Turned it on this past weekend to see if anything changed and all of a sudden it got past that point in the spinning gears(50-65%) and completed the install. In my opinion try the WIndows Device Recovery tool and get it back to 8.1. If you have the time and the patience then try going to 10 again.
    Last note; when going in an endless cycle my phone would eventually say it has no battery life left and turn off. Once it actually completed the install this weekend the battery was at 90%!! I seriously think there could be a rare bug in the firmware we are seeing as many Icon users have not had these issues.
    11-17-2015 08:35 AM
  6. tamanasi's Avatar
    Icon owners!! You people make me worry all the time. After all 930 is not much different. :|
    11-17-2015 08:47 AM
  7. IcyPwnage's Avatar
    If you reset the phone to OOBE, you should be able to get out of the restart loop. You have to first hold down the volume down and power buttons. Then when the nokia logo shows up immediately hold volume down. When a large exclamation mark appears press volume up, then volume down, then power, then volume down again. After going through the initial setup steps, you should be able to get into your phone again without using a computer.
    I had to do this when I went from 10581 to 10586 on my icon
    11-20-2015 08:52 AM
  1. Why am I unable to factory reset Windows Phone devices?
    By michael_holls in forum Windows Phone 8.1
    Last Post: 10-21-2015, 09:34 AM
  2. How can I create an Inbox All Folder in Outlook 2013 Windows 10?
    Last Post: 10-20-2015, 02:43 PM
  3. Extension support for Microsoft Edge in Windows 10 may be delayed to 2016
    Last Post: 10-20-2015, 09:00 AM
  4. Lenovo is offering up to 250 cashback, 100 for trade-in when you buy the YOGA 3 Pro
    Last Post: 10-20-2015, 08:42 AM
  5. Microsoft reveals new Surface warranty and trade-in program for businesses
    Last Post: 10-20-2015, 08:30 AM
