1. chovan's Avatar
    First thing first, I'm just sharing my experiences. If you are following the steps below, take your own risk. I'm not responsible to any equipment or property damage or personal injury.
    So, yesterday I did a bit of work on an old USB hub and now I can connect keyboard, mouse, external harddisk and etc without drawing power from the tablet. In fact, the battery level has increased overtime (approx. 1% every 30 minutes). It doesn't show on Stream 7 it's being charged when the tablet is on, if I turn off the tablet, it shows the plug symbol on screen meaning charging.
    I didn't take pictures when I do the mod but I found some picture on the net that can explain how I did it.
    The hub is very old USB 2.0 4 ports hub like this one:
    Open it up, it's somewhat like this, except the power jack (black plastic on the right) may not be populated:
    What you do is:
    1. Find a regular mini USB cable.
    2. Cut the cable.
    3. Take the half with regular USB A head, solder the power wires (red and black wires in my case) to the power jack pins. (If the power input jack is populated, you can skip this)
    4. Take the half with the mini USB head, solder the wires to the host USB pins ( replace the silver cable shown above).
    5. Depends on the hub design, you may need to solder a jump wire from the positive pin of the power in (see step 3) to the positive pin of the Host USB pins (see step 4). You only need to jump positive as the negative are all connected.
    That's it. You may have different hubs, but the idea is to introduce the external 5VDC to the host USB pins. It may not charge your tablet (or charge very slowly), but at least you can work with your tablet without worrying about the battery.
    02-25-2015 11:16 AM
  2. chovan's Avatar
    Other thoughts:
    1. A lot of discussions starts with OTG cable. However, remember, OTG is designed to connect two slave devices: Cell phone to thumb drive, or Camera to extrenal storage. We are dealling with a windows tablet, it's a full PC we don't need a OTG. Use of OTG cable only makes the tablet think it should provide power to the pheriperals and should not be charged.
    2. If you can find a mini USB cable that the ID pin is not short to GND, and put a switch on D+ and D- wire, you will be able to trick the tablet let it think the charging cable is plugged and accept charging then when you switch D+ and D- back, it will recognize the devices plugged into the USB ports.
    3. USB 2.0 hubs limits the output of each USB port at 500mA. Some can only provide 500mA 4 ports combined. So if you need more power to each power (to power up an external hdd for example), you can consider jump the positive to the USB ports as well.
    4. I did get things working, however, I found the data transfer speed from the tablet to the thumb drive is way too low ( about 1MB/S), maybe it's because the cheap hub, but I don't have another hub to test. This set up will not allow me to use a USB to DVI converter.
    5. Based on the thoughts above, I think very likely the USB hub I posted in my previous post will work: http://forums.windowscentral.com/hp-...tream-7-a.html . Even the OTG cable with charging port, the Stream may not show it's being charged but the battery level won't drop either.
    02-25-2015 11:33 AM
  1. How do I add a Powerpoint presentation to the forum?
    By Wevenhuis in forum Ask a Question
    Last Post: 11-24-2015, 07:26 AM
  2. Why can I not download an already purchased Here Drive+ on my new Lumia 735?
    Last Post: 02-25-2015, 03:20 PM
  3. Example: Why is my battery life draining so fast?
    By MANAS VIJAYWARGIYA in forum Ask a Question
    Last Post: 02-25-2015, 10:44 AM
  4. PSA: 6tin will return to the Windows Phone Store as soon as error is fixed
    Last Post: 02-25-2015, 10:42 AM
  5. How do I shoot a 4k video on a Windows phone?
    Last Post: 02-25-2015, 09:26 AM
