05-27-2013 02:48 AM
28 12
tools
  1. Adam Hel's Avatar
    Hi there,
    The title is quite explicit. Every app I can found work in background and drain my battery way faster than usual. Plus, it is completely useless as the live tile can only refresh every 20 min so it's never accurate.
    I just want a shortcut, a tile I could click on to display my battery % without anything going on in the background, does it exist?
    Cheers!
    05-18-2013 01:54 PM
  2. Vaibhav Chauhan's Avatar
    no its not possible thats why people try out all sorts of battery tile apps. & I use one battery app too, but i dont think it makes any difference on my battery life!!
    05-18-2013 02:46 PM
  3. Twitter@Firas_MD's Avatar
    I'm using battery sense on my HTC 8X and I don't think that it's draining any extra battery. Yet its a bit inaccurate.
    Adam Hel likes this.
    05-18-2013 02:58 PM
  4. Adam Hel's Avatar
    And which one do you use? It might suit me
    05-18-2013 02:59 PM
  5. th0mas96's Avatar
    they all take almost no battery at all. all they do is get the percentage and update the value on the tile every 30 minutes. I'm sure your phone drains more just by searching for network, push services etc. I use a dev-version of TimeMe that updates the percentage every minute, and it doesn't affect my battery life.
    05-18-2013 03:05 PM
  6. Church Punk's Avatar
    Cant you just ignore the live tile setting on the app? I have one called "battery" which has the option to show notification on lockscreen. I havent seen any abnormal drainage, but then again, i dont have the live tile...
    Himanshu Pandey likes this.
    05-18-2013 03:08 PM
  7. th0mas96's Avatar
    oh, solution how you want it: go to settings, background tasks and block the battery app you use. It won't update in the background, just on tapping it will open (and update the tile)
    05-18-2013 03:12 PM
  8. Geddeeee's Avatar
    I use the 'in-built' one, via Settings. No battery drain at all.
    Pinned 'Settings' to Home Screen. One tap: Settings. One swipe down: Percentage...
    05-18-2013 07:59 PM
  9. Adam Hel's Avatar
    So I've tried Battery and it was quite accurate but yeah, it was draining like hell
    05-19-2013 03:23 PM
  10. crash1989's Avatar
    It is to do with how windows phone live tile and notifications system works. There are background agents which run to update your tiles and toast notifications (and/or push notifications).
    It is clearly mentioned in the dev manuals that the agent is very tricky to work with and sometimes it might run and sometimes it wont.Generally it is told that the agents are run every 30 mins or so. Devs are explicitly told not to put any critical code in it.
    This is the reason why the battery app updates only every 30 mins or so and not regularly. Opening the app will update the live tile since the dev must have written the code during the app launch. I don't think microsoft has made exceptions for third party apps to tweak the agents in the background. Although big companies like HTC has its clock tile working pretty well updating time.
    05-19-2013 03:32 PM
  11. th0mas96's Avatar
    yep, it's a requirement in the store - they update every 30 minutes. With a developer unlocked device, you theoretically could deploy a custtom app that updates every minute and updates even in battery saver mode (completely like the HTC clock).
    05-19-2013 03:42 PM
  12. Exotic Hadron's Avatar
    I use the Battery app by Arthur Semenov and it seems okay, but... I think I am gonna remove the app as it doesn't do any better that what you get from Windows Phone settings. It only shows you that your battery drains when you actively use the phone and when you don't your battery drains smooth without spikes.
    And that's not an issue with the app that presumably uses the same OS API that reports battery voltage. That's quite expected provided that a Li-Ion battery is a voltage source and you can't measure its drain properly as voltage is kept near same all the time and then its volt-ampere diagram drops very quick when it is discharged. Battery voltage kept close to 3.7 V provided by lithium nickel manganese cobalt oxide. So practically, I don't see any real use of those apps, so I can't say why I keep using this app, probably because I like those digits changing all the time...
    05-19-2013 03:44 PM
  13. stevethenerd's Avatar
    I find the only time the app is inaccurate is when I'm charging. Although previous posts are correct, to create a live tile/lock screen notification a background tasks is necessary. My best solution to optimize battery use is to monitor these just as I would startup items on my desktop.
    Its a trade off we will have to work with at this time...
    Rome wasn't built in a day....
    Even IOS has been constantly improved with each update.
    05-19-2013 03:56 PM
  14. jaj324's Avatar
    Life is too short to obsess over whether your battery is at 83% or 75%. Charge your phone often and don't sweat your %.
    Sent from my AT&T Cali Blue HTC 8x using Board Express
    Exotic Hadron likes this.
    05-19-2013 04:05 PM
  15. OzRob's Avatar
    Most people seem to be missing the point that if you turn off ANY battery app's ability to operate in the background (Settings->Applications>Background Tasks), it won't use any battery power unless you explicitly open it.
    05-19-2013 07:40 PM
  16. Adam Hel's Avatar
    But then it'll ask me to switch background tasks on every time I open the app?
    05-20-2013 12:35 AM
  17. OzRob's Avatar
    I tried out one ages ago that asked me the first time, but never again. Can't remember which one, though.
    05-20-2013 01:19 AM
  18. Exotic Hadron's Avatar
    But how then would it be possible for the app to monitor battery status when monitoring should be made in background? When the app isn't in background, it is dehydrated by the OS and thus process' main working thread is frozen. Please correct me if I am speaking absurd.
    05-20-2013 06:54 AM
  19. beachhoppr's Avatar
    Well I'm not sure its dehydrated...
    05-20-2013 07:06 AM
  20. th0mas96's Avatar
    they all don't affect battery life. Maybe 1%/week.
    05-20-2013 08:19 AM
  21. rcranium's Avatar
    I didn't realize that all the battery apps update every 30 minutes. None of them have custom settings? Is this the same with weather apps?
    05-20-2013 12:19 PM
  22. OzRob's Avatar
    You are correct. The app would not be able to 'monitor' batter life in the background. But that's what the OP wanted - that the app only updates battery status when specifically opened.
    05-20-2013 07:52 PM
  23. OzRob's Avatar
    It's the same with ALL apps. Microsoft stipulates that apps can only update the status of live tiles once every half an hour.
    05-20-2013 07:53 PM
  24. foxbat121's Avatar
    No, you can't do that. Dev unlock merely allow you to side load xap files (for up to certain number of apps). To update more frequently than 30-minute, you need special privilege that is only available to device makers. Like HTC clock (and Nokia Storage check which can enumerate storage usages that normal app can never allow to).
    As for OP, a battery app only runs in the background once every 30 minutes and runs a few short line of code to read the battery percentage from OS and update live tile. If that little amount of work can cause a lot of battery drain, your phone needs to get serviced.
    05-20-2013 10:26 PM
  25. th0mas96's Avatar
    sure you can, there's even a clock app that does the same thing as the HTC one (TimeMe), look on arnoldvink.com
    05-21-2013 03:31 PM
28 12
  1. Replies: 15
    Last Post: 02-12-2013, 05:26 PM
  2. App that tells battery usage of each app
    By ammarmalik2011 in forum General Phone Discussion
    Last Post: 02-08-2013, 04:47 PM
  3. Replies: 2
    Last Post: 01-04-2013, 02:44 AM
  4. Iheartradio app drains battery big time
    By Guitarpik in forum Windows Phones
    Last Post: 11-29-2012, 11:29 AM
  5. do open apps drain battery
    By bevt in forum Other Operating Systems
    Last Post: 04-26-2012, 03:53 PM
