Hotmail Sync Settings and battery usage
Mainer82
73
I have a Lumia 928 and a Hotmail account, if I have the settings set to "as item arrives" when checking email, will this drain my battery any faster than "every 15 minutes"?
Laura Knotek
Retired Moderator
Mar 31, 2012
29,402
24
38
"As items arrive" should use less battery than "every 15 minutes", since "every 15 minutes" means that the device talks to the server every 15 minutes whether or not there is any new email. If its syncing every 15 minutes whether or not needed, that will use more battery than if it only syncs as needed (when there are new emails).
pdaneophyte
154
Generally the more useful cut off time is 30 minutes. It depends on how many emails you will get within that 30 minutes time.
If you receive a lot of emails within 30 minutes time you will get a better battery life if you check your mail every 30 minutes.
If you only receive a few emails (less than 5, I suppose) then you will get a better battery life if you set "as items arrive".
Bottom line, a lot of emails -> batch process. A few email -> as items arrives.
svenhassel
265
If you put the settings "as items arrive", shouldn?t the phone connect to the server often, and then drain the battery more? I?m thinking in the exact opposite way to Laura, lol.
I know it?s a different OS, but in my iPad, the instructions says that if you allow "push" (which I think has the same function as "as items arrive"), it will use more battery power.
pdaneophyte
154
No, well behaved email client usually only ping the server around every 20 minutes or so to indicate the server it is still connected to network. Note it is just saying I am here every 20 minutes or so. It isn't going to drain your battery. What is going to drain power is the quality of the network connection. If you are in bad signal area, your phone is going to raise power to maintain connection. Use wifi if you are in a bad signal area, if you can.
OzRob
604
Whether push or poll uses more battery is highly dependent on how many emails per hour you receive and what poll interval you select.
Here's an article that looks at some figures for this.
The conclusion is that push email uses the same energy as a 10 minute polling interval if you get seven emails per hour. If you get less than seven emails per hour, push is more efficient. If you get more than seven emails per hour, 10-minute polling is more efficient.
Obviously the 'break even' figure changes with the polling interval, but if you have a polling interval of say 30 mins, then this would be more efficient than push email even if you only receive a couple of emails per hour.
So 'push' is only the better option (power-wise) if you don't get a lot of emails.
OzRob
604
pdaneophyte is correct. Whether push or poll uses more battery is highly dependent on how many emails per hour you receive and what poll interval you select.
OzRob
604
Depends on how many emails you get per hour. "As items arrive" uses a 'push' from the server to deliver mail, so the phone only connects to the server when new mail is available. If you only get one email per day, the phone will only connect to the mail server once per day. If you get lots of emails, your phone will connect to the server often.
OzRob
604
I'm in agreement with sven. "As items arrive" would have to keep a near constant connection back to the server.
No it doesn't. 'Push' email technology is server-initiated. When the phone is set to "as items arrive" it doesn't connect to the server unless it gets a ping from the server to say new mail is available. Obviously, if you get a lot or emails this will happen often. If you don't get many emails, the phone will connect to the server infrequently.
Mainer82
73
I don't get a lot of email thankfully (it's a personal one, my work email on the other hand will not be added to the phone) so I'm going to try the push option. I'll keep an eye on how many I get per hour but I'm guessing it's much less than 7 an hour on average.
jacobss
