Horizontal Scrolling within window - Help
benathyde
Very pleased with my windows phone and IE 10 - only major annoyance is that on certain sites IE 10 will not scroll within an object window - such as this map :- Open Train Times
Can anyone help to get this working?
I have tried all the available free browsers as well as IE 10 but they all seem to behave exactly the same as IE 10 in this respect.
Hi,
Yes, I have faced the same issue with my local sties and no success with any browser available in the store since they all use the same Internet Explorer engine underneath.
It is just an annoyance I deal with, I don't think there is a solution for this right now. Maybe you can provide feedback to the Site you mentioned and they could check it out.
Yes, it is frustrating - unfortunately they say that they cant support all browsers - shame, IE 10 is great otherwise, very smooth and fast, just these minor niggles, was hoping somehow might have found a workround, thanks for your reply, at least it confirms what I thought, that there isnt an alternative browser yet.
zenadrone
