Over the past several weeks, my Lumia 920 has drained battery at a miserable rate. Interestingly its been only the past several weeks, as I installed WeatherFlow in June. Anyway, I tried everything. With only one app permitted to task in the background (Battery monitor app) and everything except for cellular turned off and the display set to low, I drained 16% per hour while not using the phone. By that, I mean I didn't do anything. Lay the phone on the desk at 100% charge and look again 2 hours later and its at 70% or less.
Before the obligatory, "soft reset man, soft reset" hippie mantra, I will remind you - this is a several week observation period. During that time I soft reset the phone several times. Often times more than once a day trying to cure the mystery battery drain.
Anybody who has dug DEEP into these forums will find one consistent attribute. Not always, but usually. This app - endorsed in mid June by none other than WPCentral.
I uninstalled the app earlier today. Before the second zombie wave chimes in, let me head you off at the pass. I uninstalled only WeatherFlow.
My phone has been off of the charger since 11pm and its now 2am. I spent a solid 30 minutes browsing via baconit. I have done various browsing and Facebook checking. Some text messaging and windows messenger activity. Location is on, WiFi is on, cellular is on.
When I began typing this message, the baked in Battery Saver reported 100%. Not a battery app, the system battery maintenance app.
WeatherFlow is EVIL.
Sent from my RM-820_nam_att_100 using Tapatalk
