1. chenhogi's Avatar
    Any idea whether MS is looking to change this with 8.1? Really annoying this, as I tend to miss quite a few calls when in a noisy environment.
    Don't understand the logic behind the way they chose to implement this to be honest.
    10-16-2013 04:11 AM
  2. montsa007's Avatar
    Use a loud ringtone like Nostalgia period.
    10-16-2013 04:19 AM
  3. psiu_glen's Avatar
    You want it to ring and vibrate at the same time? It does already?
    10-16-2013 04:26 AM
  4. montsa007's Avatar
    I don't even know what he wants lol, I used to miss calls but I figured out it was my poor ringtone to blame.
    10-16-2013 04:30 AM
  5. Al_2's Avatar
    It vibrates and then rings...but it doesn't do it together (similarly for notifications/texts, it vibrates and then you hear the sound, but it doesn't happen together). Not sure why it's done like that, but I agree it'd be better if it continued to vibrate when on 'vibrate and ring'.
    10-16-2013 06:26 AM
  6. chenhogi's Avatar
    So, vibrate AND ring finally coming to WP8.1, right? Yey!
    02-12-2014 01:25 AM
  7. genuine555's Avatar
    Don't know, but my ringtones just keep on playing while the phone vibrates...
    02-12-2014 11:59 AM
  8. aseefsh3001's Avatar
    if the win 8.1 vibrates & rings together, there would be many many happy customers including me...who bought lumia in EMIs
    02-25-2014 12:05 PM
  9. Boris Lozac's Avatar
    Check again, it vibrates two times, then it just continues without vibration. This is such a fail i have no words.. and it's not mentioned anywhere to be fixed for 8.1.
    02-25-2014 01:20 PM
  10. genuine555's Avatar
    Ok, I understand. I didn't even ever payed attention to that even after three lumia's...simply because it is kind of trivial.
    If it were the other way around, and the sound would cut while vibrating, that would have been really annoying, which is what I first understood what was happening to your ringtones...
    Preferences vary, so for some it may understandibly be a huge bummer getting only two vibes, but for me personally vibe is supposed to be felt, and imo if you don't feel it the first two times, you won't feel it anyway.
    The sound is to be heard, and as long as that don't cut, if you haven't felt it, you'll hear it. Also, more vibes would eat more battery, so maybe that's how you could try to see a positive side in it.
    Don't actually know why they made it that way...
    02-25-2014 06:50 PM
  11. Boris Lozac's Avatar
    OMG man that is so wrong.. offcourse i might not feel those first two times, sometimes if you're in a bus or a busy street, there's no way you'll hear the ringtone so it needs to keep on vibrating, you know, like it always did for 20 years now
    02-25-2014 07:27 PM
  12. anon(5348929)'s Avatar
    This seems to be a Nokia problem rather than a Windows Phone problem: my Nokia stops vibrating after two times, while my brother's 8X keeps on vibrating the whole time. I think the 8X's behaviour makes much more sense.
    //Edit: I read a little more about it. It seems, it vibrates every time the ringtone repeats. So, if you want it to vibrate all the time, choose a very short ringtone. Perhaps my brother has a short ringtone, and it's Windows Phone thing after all ;-)
    chenhogi likes this.
    03-06-2014 08:06 AM
  13. chenhogi's Avatar
    Interesting, thanks.
    03-06-2014 11:26 PM
  14. redkanji's Avatar
    Yeah, the phone vibrates at the beginning of the ringtone. So, if you have very short tone, it will vibrate more often.
    03-07-2014 02:07 AM
  15. mykd83's Avatar
    My options screen for Ringtones + Sounds menu doesn't look like that!! I only have an On/Off for Vibrate, nothing about "vibrate while ringing" or anything
    05-23-2014 05:52 AM
  1. AirParrot Airplay mirroring (a quick and nasty review)
    By Lurchorama in forum Other Operating Systems
    Last Post: 04-19-2014, 04:00 PM
  2. Replies: 7
    Last Post: 10-18-2013, 11:52 AM
  3. 'Glance' and 'call+SMS filter' missing
    By Memristor in forum Windows Phones
    Last Post: 10-16-2013, 09:56 PM
  4. Touch Screen And Top Buttons Stopped Working! Plz help!
    By Katelyn Warga in forum Windows Central Archive
    Last Post: 10-16-2013, 05:06 AM
  5. Lumia 1020 yellow photo tint and GDR3
    By Pinal Patel in forum Developers Corner
    Last Post: 10-15-2013, 07:34 PM
