Hey guys,
So I just updated my L920 to Amber, and i noticed that I lost about 800 mb of space. I went into Storage Check. I recall my "applications" took 8.5 gb before the update, but now they're taking 9.2 gb. I look into the applications and find that "Settings" now takes up more than 800 mb! Did this happen to anyone? Is there a solution? Help!
EDIT: Just to clarify: I went to settings>storage check>apps>details (where it shows me how much space each app is taking). Then I scrolled all the way down to find that "Settings" is taking up 853 mb. Is this normal? I don't recall it being that large. Could it be the glance setting?
