Guys I need some help. Been trying to find solutions on this forum for the past couple weeks but no joy.
I have a L925 on GRD3 but have had the battery issue about 2-3 weeks before updating. I literally get a maximum of of 5-7 hours with minimal usage (8 if I don't touch the phone, but that's rare). I've tried turning off all background tasks, location services, wifi and bluetooth without much success in increasing life. Made sure all IE tabs are closed and have reduced the frequency of the syncs of my email. The only time I really see my battery life go down by less than 1% per hour is if I turn off the data, so it's something to do with the connection and definitely not a battery issue. You can see in the attachment there was 1.5hrs this morning where I turned data off at the gym and the level pretty much didn't change. I don't know what changed but the battery life was never this bad a couple of months ago.
I wanted go get advice on if a cul of all apps that connect to the net and reinstall them one by one will help (event though I've tried removing background tasks already) or if I should just do a clean factory reset (I'm trying to avoid this as a last resort as I really don't want to loose some of my WhatsApp convo's which can't be restored). Any advice on other solutions??
