1. SamiSaifDine's Avatar
    Hi There, Today I Noticed A difference between the Picture Taken by Nokia Camera app After Shooting it Directly and When you open it from the camera roll
    So, To See The difference I Took a Photo Then At the same same Made a screenshot! and Here is what I Got :
    https://skydrive.live.com/?cid=48b12...C64B6BE29E!389
    01-13-2014 02:20 PM
  2. Memitim's Avatar
    The quality should return once you open it up in Nokia Camera or transfer it to a PC
    The Camera Roll most likely displays a lower quality of the photo so that it can load the photos faster.
    01-13-2014 02:27 PM
  3. SamiSaifDine's Avatar
    AHAA! Thanks for the tip
    01-13-2014 02:32 PM
  4. hopmedic's Avatar
    Yes, the camera roll does display a lower quality. You can also use an app called HD Photo Viewer to open any image in full resolution (not just those pics taken with Nokia Camera).
    01-13-2014 07:50 PM
  1. messaging app issue
    By zeronoise in forum Other Operating Systems
    Last Post: 01-14-2014, 12:29 PM
  2. "Other" Storage Issue with my Just activated Lumia\
    By waltzik in forum Windows Phones
    Last Post: 01-14-2014, 02:20 AM
  3. Nokia brings advertisements to HERE Maps on some Windows Phones
    Last Post: 01-13-2014, 05:32 PM
  4. Need help with Windows 8.1 RT
    By Marute in forum Other Operating Systems
    Last Post: 01-13-2014, 02:28 PM
  5. Nokia Lumia 525 Unboxing and hands on with the low-cost 1 GB Windows Phone
    Last Post: 01-13-2014, 12:45 PM
