1. SoullessOnyx's Avatar
    Hey, so I got the Lumia 920 and I charged it when I woke up this morning, I left it to fully charge and then took it off, I have not used my phone all day until about 40 minutes ago and the battery was at 93% what is not to bad I guess, I then used my phone for about 10 minutes, and my battery went down to 84% in 10 minutes...
    I have no Apps running in the background, I have the brightness set at low, I have all the sounds and vibrate off, mostly everything is turned off to keep the battery lasting longer, yet I lost a rather large amount in 10 minutes, I'm not sure what to do, why has it run down so much?
    01-29-2014 05:46 PM
  2. kyriacou48's Avatar
    Hey SoullessOnyx,
    Having owned a Lumia 920 (on a 1520 now), this can happen from time to time. What were you doing on your phone? I have seen drainage like that when playing 3D Games (Asphalt is a big killer). If you weren't playing games, I would suggest to check the following:
    -Location turned OFF
    Wifi turned OFF (or ensure that under Wifi>Advanced that "keep wifi on while the screen is timed out" is unchecked)
    seeing as its not poor battery life overall, it seems it must be app related.
    Which app/s were you using during the 10 minutes of usage? some apps are really bad for battery drainage.
    Regardless, give your phone a soft reset (hold power button and DOWN volume key for 20 seconds).
    Another thing to try is fixing your battery reader inside your phone. Try completely draining your phone til it's dead, then doing a complete full charge. turn your phone off and on, and top up the battery again to 100%.
    Let me know how you go and hope this helped!
    Cheers,
    Chris
    01-29-2014 06:08 PM
  3. Boris Lozac's Avatar
    I just love these suggestions lol. Just turn the phone OFF and put it in the drawer, no drain, but hey, when you open the drawer you have something nice to look at.
    01-29-2014 06:47 PM
  4. kyriacou48's Avatar
    I had meant to say that WIFI should be turned off when the phone isn't in use. Check usage on most devices, you'll see that screen brightness and wifi are the biggest battery killers.
    01-29-2014 07:06 PM
  5. SoullessOnyx's Avatar
    Hey SoullessOnyx,
    Cheers,
    Chris
    I was using "Nokia Camera" I also have my Facebook and Twitter linked, Imagine that would take a lot of power, I also have location off and Wi-Fi to turn off when locked.
    01-29-2014 07:16 PM
  6. James8561's Avatar
    actually in my experience cellular data is the biggest radio related battery drain and wifi is much less.
    do leave wifi on.
    turn off Location, NFC, Bluetooth. (if not in use)
    01-29-2014 07:16 PM
  7. SoullessOnyx's Avatar
    do leave wifi on.
    The only thing I have turned on is Wi-Fi and that turns off when locked.
    01-29-2014 07:20 PM
  8. HeyCori's Avatar
    01-29-2014 07:29 PM
  1. Issues moving ATT Lumia 1520 on T-mobile USA
    By Alpo714 in forum Windows Phones
    Last Post: 02-05-2014, 12:17 AM
  2. Nokia Lumia 520 Amber update bug (HELP)
    By Igor Tomic in forum Windows Phones
    Last Post: 02-03-2014, 09:18 AM
  3. Battery life of Surface Pro 2
    By raxy21 in forum Microsoft Surface Pro
    Last Post: 01-31-2014, 10:23 AM
  4. No Amber update on unlocked phone
    By gwinegarden in forum Other Operating Systems
    Last Post: 01-30-2014, 04:04 PM
  5. lumia 520 black update help
    By saniraj in forum Windows Phones
    Last Post: 01-29-2014, 07:48 PM
