1. Devmer11's Avatar
    I have the Music duplication problem but also have a strange problem with my storage the Nokia app shows my usage but the phone doesn't report it wp_20140313.png
    03-13-2014 06:35 PM
  2. Checki's Avatar
    Get another SD card
    L620 - Tapatalk
    03-13-2014 06:39 PM
  3. Devmer11's Avatar
    that's not a solution considering it's an OS bug and an SD card doesn't explain the phone storage not reporting
    03-13-2014 06:42 PM
  4. Checki's Avatar
    I bought a new class 10 card, had the problem. Tried formatting and everything else. Put in my old class 10 card, everything fine. Switch again, problem again. Explains alot to me...
    L620 - Tapatalk
    03-14-2014 07:19 AM
  5. Saksham Sharma's Avatar
    I'll tell you, the music info is cached, so do one thing, open your sd card from pc, view hidden files, open wpsystem folder, delete wpsettings file, and restart your phone, problem gone ! :)
    Or you can do the same things from pocket file manager... I had done on that...
    Another way is, keep all your songs in some other folder like 'pc music' or something like that...
    03-14-2014 07:21 AM
  6. Checki's Avatar
    I will try
    L620 - Tapatalk
    03-14-2014 07:30 AM
  7. Checki's Avatar
    Well, I can't delete the file nor the folder. Says its protected. Can't get rid of protected status...
    L620 - Tapatalk
    03-14-2014 08:10 PM
  8. Saksham Sharma's Avatar
    L620 - Tapatalk
    someone on the forums deleted it with pocket file manager, though you'll have to spend $2 for it... Or else you can put your sd in a card reader/some non-windows phone, and then do it. It works, he had testified.
    You can try a soft reset too, it MIGHT work... Hold volume down+power key for 15-20 seconds, you wont lose any data. This is just a possibility, i dont know whether it would work or not. Do let me know if this works, if it doesn't, then you can either try the first method, or simply cut your music files and keep them in a new folder inside your sd, that would be the end of your troubles...
    03-14-2014 11:26 PM
  9. Checki's Avatar
    Of course I tried reset. I can't delete the file,even with no extra programs made to delete locked files. And no, I don't spend money for that problem, sorry MS :) . If I put them in a new folder, I don't have my playlist anymore...i wait for gdr3 and black, maybe they fix.
    L620 - Tapatalk
    03-15-2014 06:02 AM
  10. yaro da yaar's Avatar
    Move all of your songs to pc, then restart ur phone and check if all the songs are removed from phone or not. Then paste all the songs back to sd card or phone memory and again restart ur phone. Now your problem would be history. I had the same problem in past.
    Don't use zune for transferring songs, you can use default file explorer (My Computer). If you use Windows 8/8.1, you can use windows phone app.
    03-15-2014 06:22 AM
  11. Checki's Avatar
    Lol, Zune? What's that :) of course I use WP app for desktop...
    But tried this before, after few days the dups are back. I think its the WP desktop app. And the SD card. Ah I don't know and i don't care.
    L620 - Tapatalk
    03-15-2014 07:00 AM
  12. Saksham Sharma's Avatar
    L620 - Tapatalk
    it is possible that it is due to the wp app on pc, because i only had duplicates when i used to sync with it, now i just use 'this pc' :-P
    03-15-2014 08:46 AM
  13. Checki's Avatar
    Nope, I had problem with the app, then hard reset, didn't use the app, problem again...
    L620 - Tapatalk
    03-15-2014 10:50 AM
  14. Checki's Avatar
    Now I have black, and did hard reset after update plus formatting SD card. Lets see, that's all I can do
    03-19-2014 08:16 AM
  1. How to create and manage Xbox Music playlists on Windows Phone and Windows 8
    Last Post: 02-28-2015, 12:07 PM
  2. Xbox Music or Nokia MixRadio
    By RobinPaul in forum Microsoft News & Rumors
    Last Post: 12-05-2014, 05:32 PM
  3. Have duplicates of some contacts
    By msweig in forum Other Operating Systems
    Last Post: 03-15-2014, 08:21 AM
  4. screen background problem
    By theblackcat1me in forum Other Operating Systems
    Last Post: 03-14-2014, 12:51 PM
  5. Cloud Storage on Windows Phone which service is the best value?
    Last Post: 03-13-2014, 08:23 PM
