1. dkp23's Avatar
    Just installed 8.1. Had some account syncing issues getting stuck. Did a airplane mode, reset, delete, and add back accounts and it seems to work. It isn't stuck on syncing anymore.
    So through all this, i have my phone on tryign to play around with settings and put it on charge at 76%. Went to the bathroom and came back, now at 74%? on charge and the phone doing nothing.
    The phone is quite warm though as well.
    Anybody else havign this issue?
    04-14-2014 11:53 AM
  2. Cormango's Avatar
    I find after applying updates that the percentage shown for the battery is inaccurate. It takes another charging cycle before it starts working properly.
    04-14-2014 12:23 PM
  3. liam-ward's Avatar
    I had this so I turned it off and on and plugged it into a wall socket. Was previously in the USB charger.
    04-14-2014 01:06 PM
  1. Replies: 28
    Last Post: 03-18-2015, 01:59 PM
  2. Multiple accounts stuck on syncing after upgrade. Battery draining!
    By Lundon44 in forum Other Operating Systems
    Last Post: 03-14-2015, 02:27 PM
  3. How do you add apps to the notification center?
    By Highdefjunkie in forum Other Operating Systems
    Last Post: 04-14-2014, 11:17 AM
  4. Do you want to enable Cortana outside the US? Here's how you do it
    Last Post: 04-14-2014, 10:50 AM
