1. liam-ward's Avatar
    Thanks to 8.1 I have seen that the item using up the most of my battery is the people Hub. It is using up about 15x as much as the next one down. Any ideas how to decrease this or should i just delete the accounts in the WP accounts?
    04-14-2014 12:38 PM
  2. ItsMcDiddles's Avatar
    Soft reset? Or if you can't fix do a hard reset.
    Posted via the WPC App for Android!
    liam-ward likes this.
    04-14-2014 12:44 PM
  3. daniel187's Avatar
    Same here just the people hub is draining like crazy
    04-16-2014 10:10 PM
  4. liam-ward's Avatar
    Did a reset and it worked. :) thanks
    04-18-2014 01:07 AM
  1. WP8.1 Tips & Tricks
    By a5cent in forum Other Operating Systems
    Last Post: 11-02-2015, 05:17 PM
  2. Email attachments from office hub?
    By Ivanr53 in forum Other Operating Systems
    Last Post: 08-31-2014, 01:12 AM
  3. Adding home and work addresses to notebook
    By ygtgngr in forum Windows 10
    Last Post: 04-16-2014, 08:43 PM
  4. Battery Drain - Charging and battery doing down?
    By dkp23 in forum Other Operating Systems
    Last Post: 04-14-2014, 01:06 PM
  5. Question about Here Drive and My Commute
    By Carkid367 in forum General Phone Discussion
    Last Post: 04-14-2014, 12:33 PM
