1. Dhaval Thakur's Avatar
    Guys I installed wp 8.1 dev. Preview and when I try to open battery saver option in settings it does not opens! Please suggest me how to do it.. I need to find out which app is consuming my battery .. As for now I am using other 3rd party app .. Please help! Asap
    04-16-2014 11:20 AM
  2. Nokia Boy's Avatar
    Did you Reboot your phone? if that still don't work do a Soft Reset
    04-16-2014 11:21 AM
  3. Dhaval Thakur's Avatar
    How to do soft reset? I only know that reset in which all data is removed
    04-16-2014 11:59 AM
  4. RottingOrange's Avatar
    Same here. Lumia 820 (AT&T unlocked) and I have no Battery Saver app, and Battery Saver in settings will not open. :\ I've rebooted my phone, no luck. Any ideas?
    04-16-2014 01:36 PM
  5. Dhaval Thakur's Avatar
    Mine too 820 but I am from india
    04-16-2014 01:38 PM
  6. Nokia Boy's Avatar
    To do Soft Reset Hold Volume Down + Power button for about 10 seconds till you feel the phone vibrate,if that don't work,hard reset might be required :(
    04-16-2014 02:14 PM
  1. Cortana is not RESPONDING to my commands
    By GohanGautham in forum Windows 10
    Last Post: 11-28-2015, 11:50 PM
  2. Windows Phone 8.1-update or not?
    By Ryan Schouten in forum Other Operating Systems
    Last Post: 05-02-2014, 12:31 PM
  3. Cortana not coming after windows phone 8.1
    By ajaya p in forum Windows 10
    Last Post: 04-18-2014, 07:46 PM
