Help! my phone went a bit haywire yesterday and i after reboot, no data connection!
Moiz Mian
824
I can't connect to any data at all. I have a 1020 and my LTE bars are showing but it won't connect to the internet, and WiFi doesn't work either. My phone just completely wiped it's internet connection. Is there anything I can do short of a hard reset?
Thanks!
Evronian
28
Hi! Have you checked time and date settings? It happened to me too after a reset, time and date were wrong (it was set back to the production day of the device I guess) setting them correctly solved the problem for me. Hope it helps!
grizzlyaddams
166
I had the same problem on an HTC phone and did another hard reset using the hardware key combo and the cellular network settings came back.
Moiz Mian
824
Thank you! Problem solved, I guess I was playing with VPN and even though it wasn't working I accidentally left it active, so turned that off, and internet was back. Phew...I was really freaking out
velocityxs
