how hard reset will effect the applications installed on the SDcard
sachin hegde
22
most of us here will bump into this problem sooner or later. i have installed wp8.1 and enjoying it so far, i have most of my apps, games installed in SDcard. due to some problems i have to do a hard reset off my mobile..
i wanted to know what is the effect of hard reset on those apps which are installed on my SDcard. do i need to reinstall them or they can be used without any problems and along with there app data.
SwimSwim
1,173
Due to how WP8.1 handles SD cards, and only lets SD cards be used on one phone, it will likely require you to format the SD card after a hard reset, effectively loosing everything.
DavidinCT
Feb 18, 2011
3,310
I would think otherwise one of these options but, cant say for sure (If your going to hard reset, try it to see what happens)
1. As above, might have to format card, or WP would remove the folder when you tried to install a new app after hardreseting it
2. The apps might stay but, you would have to reinstall them...
3. They might be there but, be dead, just like if you Reinstalled Windows on your PC but, all your apps were on another drive, you woudl need to reinstall them to the same folder to get them working again or create shortcuts (you cant do that in WP)...
sachin hegde
22
i don't think it will format whole SDcard as there are other data along with the app which are installed. and i will use same mobile+ SDcard combination so not sure how wp 8.1 deal with that, it may recognize it's own app on SDcard or it may not, these are the two basic possibilities.
sachin hegde
22
along with these there is one more likely possibility that WP8.1 will delete(or prompt user to delete) all the app already installed in the SDcard before installing a new one
rubenwidjaja
135
I did hard reset after I installed wp 8.1
all apps installed in SD won't delete but you can't use it either, so it will still there until you ask wp 8.1 to install app in your SDcard. WP 8.1 will confirm you that there are apps in your SDcard and if you want install new apps you need to delete it.
Of course wp 8.1 will delete it automatically and you can install new apps in your SDcard. So your apps before hard reset will deleted and you must reinstall your apps.
DavidinCT
Feb 18, 2011
3,310
If you reinstall, does it keep your game saves ?
DBZo07
586
Interesting, I was planning to create a query thread but search option saved my time.
Op I request to share the whatever you did, it will help me or people like me.
Thanks
Nimdock
687
The more I think about this the more I am convinced that if i ever get a phone with SD card support (L920 right now) I would definitely only use the SD card for music, pictures, documents, things of that nature.
aximtreo
2,385
Would it be possible to copy the SD Card contents to your PC and then move it back once you do the hard reset. I suspect you will be forced to format the SD card as part of the hard reset. Whether the material will show once you move it back to the SD card is another question.
Someone that is forced to do a hard reset might give this a try and see what happens. Better we know from one or a small few if it works as opposed to learning from many that it doesn't work.
sachin hegde
22
formatting SDcard is optional in hard reset. all the data including app data will be there in SDcard but as you reset the mobile the application certification will be removed hence the apps cannot be used
Nimdock
687
How about non-app data? Will Music/pics.docs/etc. be available normally?
lsmachado
676
So, if I have to hard reset, is it best NOT to remove the SD card first? Should I just leave it in the phone during the hard reset?
Brilliantick99
