1. smarty99's Avatar
    Hii All
    Pls I need your help...
    I also had the problem with my Lumia 920 , that the power button wasnt responsive ....
    if I have switched the device off - If I have wanted to get it back on - most of the times when I have pressed the power on button
    it didnt turn the device on , only when I did soft reset the device turned back on ....
    My battery went went to 0 precent and I didnt have the time to connect the device to charger
    so the device turned itself off..
    Now I cant turn the device on any more
    the power buton is not responding ...... soft reset, hard reset does nothing because I dont have battery power
    of connecting the device to a charger or to the computer via the usb cable also dont do anything to the device ,
    my device is dead only because i dint have the time to connect him to a charger in time ??
    what can I do ?
    Pls help
    04-25-2014 09:04 AM
  2. rdubmu's Avatar
    While plugged in press the volume down button and the power button at the same time.
    Shahriyar93 likes this.
    04-25-2014 09:10 AM
  3. Xpider_MX's Avatar
    If the battery charge is zero, it needs some time plugged to the charger to wake up, it needs some percent of charge.
    Sent from my RM-820_lta_lta1_272 using Tapatalk
    04-25-2014 09:19 AM
  4. foxbat121's Avatar
    Also make sure it is plugged into the original AC wall charger, not some random USB port.
    The power button can't wake up phone is a known issue for most Lumia phones. The work around that works for me so far is press and hold camera button to launch camera and it will wake up the phone. Also, remove Cortana live tile may help prevent it from happening again.
    04-25-2014 09:27 AM
  5. Shahriyar93's Avatar
    oh maaaaan!!!! god bless you!!!! **** it was really annoying in my mind. thanxxxxxxxxxxxxxxxxxx
    06-01-2014 10:25 AM
  1. Nokia Camera not saving videos
    By Rafael Marcondes in forum General Phone Discussion
    Last Post: 05-16-2014, 10:38 AM
  2. Bug with Battery Saver
    By RobinPaul in forum Other Operating Systems
    Last Post: 05-02-2014, 08:17 AM
  3. The Last Nokia Flagship in the US
    By Indistinguishable in forum Windows Phones
    Last Post: 04-28-2014, 03:43 PM
  4. Transfer start screen layout to another phone?
    By patstar5 in forum Other Operating Systems
    Last Post: 04-25-2014, 08:10 AM
  5. Top Car Racing games for Windows Phone
    Last Post: 04-25-2014, 07:20 AM
