1. irvin792's Avatar
    Sorry of this is posted somewhere else, I know the forums are full of battery problem threads but I'm curious about others with this exact problem with the Phone showing as the highest drain with nothing else even coming close even though the phone has maybe made 1 call all day and was using IE11 and texting much much more
    This is regarding my wife's 920
    04-30-2014 01:28 AM
  2. Laura Knotek's Avatar
    How is your coverage in the area where you are? If signal is poor, and your device is searching for a signal, that will cause battery drain. If you have WiFi, anything that uses data will not show battery drain, but the phone will, since voice does not use IP at this time. Once LTE-Advanced is available, and phone calls are done via data, not voice, then there won't be any differences; however, at this point, voice uses mobile network, not WiFi, which would drain battery in areas where signal strength is low.
    04-30-2014 01:35 AM
  3. irvin792's Avatar
    Signal is very good at home and work, before 8.1 was installed battery would last much longer. I have scoured the various threads and tried all the tips and fixes people suggest......i am at a total loss, my wife's 920 is dying in 5 hours.........where as my 1520 is running great, same if not better than 8.0
    LTE however is not yet available at my home or our work area but AT&T "4G" is strong
    04-30-2014 01:44 AM
  4. Laura Knotek's Avatar
    I have a 920, and I haven't noticed any differences in battery life between 8.0 and 8.1. I've never used battery saver.
    04-30-2014 01:46 AM
  5. irvin792's Avatar
    Yea my 1520 is running great
    04-30-2014 01:51 AM
  6. Laura Knotek's Avatar
    What settings is your wife using? Does she have NFC and location enabled? What apps does she have running in the background? Does she play a lot of games?
    04-30-2014 02:10 AM
  7. irvin792's Avatar
    4 email accounts all set to manually sync
    Internet sharing off
    Lock screen timeout 1 min
    Wi-Fi on
    Bluetooth off
    NFC off
    Battery saver off (read that it may be a culprit)
    Brightness automatic
    Backup all off
    Find my phone only second box checked
    Sync my settings all off
    Quiet hours off
    Location on
    Advertising ID on
    Feedback enabled
    Sunlight readability on
    Touch sensitivity normal
    Double tap to wake on
    Glance off
    Apps running in background : Cortana, Battery Saver, Internet Explorer, Facebook, Calendar, Here Drive+, Weather, OneDrive, Live Tile countdown, Chase Mobile, Skype
    (7 above apps are not OS apps)
    She never ever plays games
    Sorry for the long post, trying to be thorough
    04-30-2014 02:53 AM
  1. Will this phone work with tmobile?
    By crisdiaz01 in forum Carrier Discussion Lounge
    Last Post: 05-12-2014, 12:12 PM
  2. Need help finding a replacement for my Windows phone
    By SgtBigRig in forum Microsoft News & Rumors
    Last Post: 04-30-2014, 11:14 PM
  3. About New video app in wp 8.1
    By prasath1234 in forum Other Operating Systems
    Last Post: 04-30-2014, 11:01 AM
  4. Why are apps so heavy with WP?
    By bionicgt in forum General Phone Discussion
    Last Post: 04-30-2014, 12:01 AM
  5. ip cameras that work well with win phone ??
    By gibbyhome in forum Other Operating Systems
    Last Post: 04-29-2014, 10:28 PM
