1. emperor_skull's Avatar
    I have noticed that after the latest windows phone 8.1 developer preview update, that my Lumia 925 will not make any sound when is plugged to a power outlet, am I the only one with this problem??
    07-18-2014 08:18 AM
  2. Pete's Avatar
    Nope. I've not heard the charging ding in some months now. May have been removed in WP8.0 GDR3 even.
    07-18-2014 08:22 AM
  3. ByeVanno's Avatar
    The update removed all sound from my phone and volume controls no longer work
    07-18-2014 08:26 AM
  4. emperor_skull's Avatar
    Well mine is just the charging sound
    07-18-2014 01:18 PM
  5. emperor_skull's Avatar
    And I noticed something else my battery life has worsen since the update
    07-18-2014 01:19 PM
  6. nyolc8's Avatar
    I'm starting to get afraid about the cyan update after seeing these topics... :D
    07-18-2014 03:47 PM
  7. Ashalinia's Avatar
    Might want to check if you have Quiet Hours on too.
    07-18-2014 11:33 PM
  8. Conan143's Avatar
    Try soft reset or hard reset
    My lumia 925 has no problems and is rocking with robust performance and the battery life is better than before and the sound when plugged into charger still works on all major phones...
    07-19-2014 04:23 AM
  9. emperor_skull's Avatar
    No is not on
    07-19-2014 04:23 AM
  10. Conan143's Avatar
    07-19-2014 04:24 AM
  11. emperor_skull's Avatar
    have tried soft reset but nothing, all other sounds are working
    07-19-2014 04:24 AM
  12. Conan143's Avatar
    kk then navigate to Settings > ringtones+sounds > Scroll down and check whether the option system alerts is ticked or not...If not tick it...
    After try plugging your phone to computer usb or power socket and then see if the sound alert works..
    This should work...
    07-19-2014 04:30 AM
  13. emperor_skull's Avatar
    This should work...
    thanks it did
    07-19-2014 07:37 AM
  14. gwinegarden's Avatar
    I've noticed that, sometimes, if the display is on, when I put the phone on the charger, it does not make the sound. If the display is off, it does.
    07-19-2014 07:42 AM
  15. corey_blackstock's Avatar
    I still have the charging sound with WP8.1.. But the sounds is different from WP8
    07-19-2014 07:47 AM
  16. Compiux's Avatar
    I miss the old sound. The new one is very quiet and... I don't know. Lifeless :P
    08-01-2014 07:02 PM
  1. squeak sound on my 1320
    Last Post: 07-18-2014, 01:35 PM
  2. Microsoft quietly kills their 3D Touch Windows Phone codenamed 'McLaren'
    Last Post: 07-18-2014, 12:46 PM
  3. Beyond Gravity, a great time waster of a game for Windows Phone
    Last Post: 07-18-2014, 07:42 AM
  4. Google promises to fix Chrome bug on Windows, causing laptop batteries to drain
    Last Post: 07-18-2014, 07:11 AM
  5. Magic Jigsaw Puzzle for Windows 8, a collection of picture puzzles to pass the time with
