1. SteveSAPA's Avatar
    Hi All,
    When i went to bed last night my battery was on 84%. I woke up an hour late this morning as my alarm did not go off as my phone died during the night.
    This is the 2nd time it has happen in the past month.
    Is there any way i can find out if / what app is causing this?
    Besides these 2 times, my battery is usually really good. i usually get about 3 full days from 1 charge.
    07-28-2014 09:56 PM
  2. Aviskri's Avatar
    Check the background tasks swiping left in the settings, if you're in 8.1 go to battery saver instead. Soft reset so any rampant process will reset. If it continue you can hard reset to see if it fixes. Also check which apps you've installed, some bad quality apps can cause this.
    07-28-2014 10:14 PM
  1. Airtel in India on my TMO Simple Choice Plan
    By worldspy99 in forum Carrier Discussion Lounge
    Last Post: 09-21-2016, 03:52 AM
  2. Unlocked ATT On Tmobile
    By sguy156 in forum Windows Phones
    Last Post: 08-10-2014, 10:22 AM
  3. Battery Saver Always On
    By jmagill01 in forum Windows Phones
    Last Post: 07-29-2014, 08:05 AM
  4. Verizon to get HTC One (W8) for Windows Phone on August 21
    Last Post: 07-28-2014, 08:30 PM
  5. Lumia Cyan available for Lumia 625 on Telus
    By Cormango in forum Windows Central Archive
    Last Post: 07-28-2014, 05:10 PM
