belodion
Member
Just check this out Belodion. This observation is not supported by detailed measurements
Well I've removed a load of them now, for example a lot of the many many photography apps which I realised I never used. I may put some back because I think my battery problem is now fixed. I've posted about it elsewhere but will repeat here. After a soft reset I noticed three app updates had been trying for a week to download. I'd received no notification of this in the App Store tile. During this time, battery usage graph showed many small downward steps, presumably caused by updates repeatedly trying to download. I downloaded them manually and now the battery usage graph descends in a smooth line. Consumption seems back to normal. The soft reset may have had a beneficial effect as well.
Posted via Windows Phone Central App
